Setting the FUSION PartyBus Device as a Wireless Access Point
Before you can connect additional FUSION PartyBus™ devices or smartphones to a FUSION PartyBus device wirelessly, you must configure at least one device as a wireless access point. This is not necessary if you installed a wireless router or other wireless access point on the network.
  1. Select Apps > Tools > Music > Settings > NETWORK > WI-FI ACCESS POINT.
  2. Select SSID, and change the default SSID, or name, for the wireless access point (optional).
  3. Select AP SECURITY, and change the security type for the access point (optional).
    NOTE: It is strongly recommended that you use the default WPA2 PERSONAL AP SECURITY setting. It is the most widely-used and secure wireless security protocol.
  4. Select PASSWORD, and change the default password for the access point (optional).
  5. If necessary, select COUNTRY, and select your region.
  6. Select CHANNEL, and select a channel range for the access point (optional).
  7. Select SAVE.
    You can adjust the wireless access point configuration at any time (Wireless Access Point Settings).
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
