Streaming from a FUSION PartyBus Device on the Network
Before you can stream from a device on the network, you must set up and configure your FUSION PartyBus™ devices according to the installation instructions.
NOTE: You cannot stream the Apple® AirPlay® source to other stereos on the network using the FUSION PartyBus feature.
  1. Select the source icon.
    The source icon is in the lower-left corner of the stereo screen and shows the source that is currently playing.
  2. Select PARTYBUS
    TIP: You can press and hold the source icon to show available FUSION PartyBus devices.
    The device shows a list of available FUSION PartyBus devices on the network.
  3. Select the device you want to stream from.
The stereo begins streaming the same source as the connected FUSION PartyBus device and a green border appears around the device screen. All media playback functions affect both devices.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
