FUSION PartyBus Networking
The FUSION PartyBus™ networking feature allows you to connect multiple compatible stereos and zone stereos together on a network, using a combination of wired or wireless connections.
A FUSION PartyBus stereo, such as an Vieo™ RV 750 stereo, can stream sources to other FUSION PartyBus devices connected to the network. Connected FUSION PartyBus devices can also control media playback on the FUSION PartyBus stereo. A FUSION PartyBus zone stereo, such as an Apollo™ SRX400 zone stereo can stream from a FUSION PartyBus stereo, but cannot stream sources to other FUSION PartyBus devices on the network.
You can connect up to eight FUSION PartyBus devices on a network wirelessly.
Diagram of PartyBus groups with callouts
In the image above, one Vieo RV 750 stereo Call-out number one connects to a wireless router Call-out number two and to two Apollo SRX400 zone stereos Call-out number three. The two FUSION PartyBus stereo zone stereos can stream sources from the FUSION PartyBus stereo.
A FUSION PartyBus zone stereo is not the same thing as a speaker zone. It is an independent stereo that can either play media from connected sources or stream from a FUSION PartyBus stereo on the network. You can connect a FUSION PartyBus zone stereo, such as an Apollo SRX400 zone stereo, to a single speaker zone Call-out number four. You can connect a FUSION PartyBus stereo, such as an Vieo RV 750 stereo, to multiple speaker zones Call-out number five to cover a larger area with that stereo. FUSION PartyBus devices cannot control the speaker volume of another stereo. You can adjust the volume of speakers or speaker zones connected directly to the stereo only.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
