Troubleshooting
The stereo does not respond to key presses
Hold
until the stereo turns off, and turn it on again to reset the stereo.
- Disconnect power to the stereo for two minutes to reset the stereo.
The stereo does not receive DAB stations
- Ensure the stereo is set to a tuner region where DAB stations are broadcast. (Setting the Tuner Region)
- Check the antenna port and power settings for the connected antenna (Configuring the Antenna Ports for DAB and FM Antennas).
- Connect a third-party powered DAB antenna to improve DAB reception.
- For additional information, go to support.garmin.com and contact Product Support.
My Bluetooth audio is interrupted by short breaks
The stereo does not display all song information from my Bluetooth source
The availability of song information such as song title, artist name, track duration, and album cover artwork depends on the capability of the media player and music application.
Network Troubleshooting
If you cannot see or connect to Fusion Apollo devices on the network, perform these steps.
Network Status Icons
A network-status icon is shown on some screens of the stereo. You can refer to this table to understand the appearance of the icon and help diagnose issues with the Fusion PartyBus™ network.
The stereo is configured for a wired network connection and connected to a wired network using an Ethernet cable. |
The stereo is configured for a wired network connection, but cannot detect the wired network. An Ethernet cable may not be connected or there may be other problems with the network. |
The stereo is in Wi‑Fi accessory configuration (WAC) mode, which allows for an easy connection to Apple® devices. |
The stereo is configured as a wireless access point. |
The stereo is configured as a wireless client and connected to a wireless access point. The number of bars indicates the signal strength. |
The stereo is configured as a wireless client, but is not connected to a wireless access point. There may be a problem with the connection settings or with the wireless access point. |
Software Update Troubleshooting
If a stereo software update you downloaded from the Garmin website does not complete successfully, perform these steps.
- Make sure the update file you downloaded is intended for the stereo model you are updating. Only software update files intended for the specific stereo will update the stereo.
- Make sure the update file is a newer version than what is presently installed on the stereo. Only newer software update files can be installed on a stereo.
- Make sure the update file was extracted from the .zip file and loaded onto the root of the USB flash drive. When properly prepared, the USB flash drive will have a directory named Garmin containing the update file.
- Make sure the USB flash drive is formatted using the FAT32 file system. The stereo will not apply an update from a USB flash drive formatted using the NTFS file system.
- If the stereo is part of a Fusion PartyBus network group, remove it from the group before starting the update.
The stereo keeps locking up when connected to an Apple device
- Press and hold the power button to reset the stereo.
- Reset the Apple device. Go to www.apple.com for more information.
- Make sure you have the latest version of iTunes® and the latest operating software on your Apple device.
