Setting an Alert
  1. Hold MENU.
  2. Select Activities & Apps.
  3. Select an activity.
    NOTE: This feature is not available for all activities.
  4. Select the activity settings.
  5. Select Alerts.
  6. Select an option:
    • Select Add New to add a new alert for the activity.
    • Select the alert name to edit an existing alert.
  7. If necessary, select the type of alert.
  8. Select a zone, enter the minimum and maximum values, or enter a custom value for the alert.
  9. If necessary, turn on the alert.
For event and recurring alerts, a message appears each time you reach the alert value. For range alerts, a message appears each time you exceed or drop below the specified range (minimum and maximum values).
GUID-2A58ED2A-14A3-4161-ADB5-259E1781AF1B v7
July 2024
