Stopping an Activity
- Press STOP.
Select an option:
To resume your activity, select Resume.
To save the activity and return to watch mode, select Save > Done.
To suspend your activity and resume it at a later time, select Resume Later.
To mark a lap, select Lap.
To navigate back to the starting point of your activity along the path you traveled, select Back to Start > TracBack.
NOTE: This feature is available only for activities that use GPS. -
To navigate back to the starting point of your activity by the most direct path, select Back to Start > Straight Line.
To measure the difference between your heart rate at the end of the activity and your heart rate two minutes later, select Recovery HR, and wait while the timer counts down.
To discard the activity and return to watch mode, select Discard >
NOTE: After stopping the activity, the device saves it automatically after 30 minutes. -
