Dive Terminology
- Central nervous system (CNS)
A measure of central nervous system oxygen toxicity caused by exposure to increased partial pressure of oxygen (PO2) while diving.
- Closed-circuit rebreather (CCR)
A diving mode used for dives performed with a rebreather that recirculates exhaled gas and removes carbon dioxide.
- Maximum operating depth (MOD)
The greatest depth at which a breathing gas can be used before the partial pressure of oxygen (PO2) exceeds the safe limit.
- No decompression limit (NDL)
A dive that does not require decompression time while ascending to the surface.
- Oxygen toxicity units (OTU)
A measure of pulmonary oxygen toxicity caused by exposure to increased partial pressure of oxygen (PO2) while diving. One OTU is equivalent to breathing 100% oxygen at 1 ATM for 1 minute.
- Partial pressure of oxygen (PO2)
The pressure of the oxygen in the breathing gas, based on depth and oxygen percentage.
- Surface interval (SI)
The amount of time that has elapsed since the completion of the last dive.
- Time to surface (TTS)
The estimated amount of time it will take to ascend to the surface, including decompression stops.
