Controls
The controls menu lets you quickly access watch features and options. You can add, reorder, and remove the options in the controls menu (Customizing the Controls Menu).
From any screen, hold LIGHT.
Icon |
Name |
Description |
Alarm Clock |
Select to add or edit an alarm (Setting an Alarm). |
Altimeter |
Select to open the altimeter screen. |
Alt. Time Zones |
Select to view the current time of day in additional time zones (Adding Alternate Time Zones). |
Assistance |
Select to send an assistance request (Requesting Assistance). |
Barometer |
Select to open the barometer screen. |
Battery Saver |
Select to enable or disable the battery saver feature (Customizing the Battery Saver Feature). |
Backlight |
Select to adjust the screen brightness (Changing the Screen Settings). |
Broadcast Heart Rate |
Select to turn on heart rate broadcasting to a paired device (Broadcasting Heart Rate Data). |
Compass |
Select to open the compass screen. |
Do Not Disturb |
Select to enable or disable do not disturb mode to dim the screen and disable alerts and notifications. For example, you can use this mode while watching a movie. |
Find My Phone |
Select to play an audible alert on your paired phone, if it is within Bluetooth® range. The Bluetooth signal strength appears on the Descent™ watch screen, and it increases as you move closer to your phone. |
Flashlight |
Select to turn on the screen to use your watch as a flashlight. |
Lock Keys |
Select to lock the buttons to prevent inadvertent presses. |
Moon Phase |
Select to view moonrise and moonset times, along with the moon phase, based on your GPS position. |
Music Controls |
Select to control music playback on your phone. |
Phone |
Select to enable or disable Bluetooth technology and your connection to your paired phone. |
Pool Mode |
Select to enable or disable the pool mode for diving. When the watch is in pool dive mode, the tissue load and decompression lockout features function normally, but dives are not saved to the dive log. The pool dive mode turns off automatically at midnight. |
Power Off |
Select to turn off the watch. |
Reference Point |
Select to set a reference point for navigation (Setting a Reference Point). |
Save Location |
Select to save your current location to navigate back to it later. |
Set Time with GPS |
Select to sync your watch with the time on your phone or using satellites. |
Sleep Mode |
Select to enable or disable Sleep Mode (Customizing Sleep Mode). |
Stopwatch |
Select to start the stopwatch (Using the Stopwatch). |
Sunrise & Sunset |
Select to view sunrise, sunset, and twilight times. |
Sync |
Select to sync your watch with your paired phone. |
Timers |
Select to set a countdown timer (Starting the Countdown Timer). |
Wallet |
Select to open your Garmin Pay™ wallet and pay for purchases with your watch (Garmin Pay). |
