HRM-Pro Running Pace and Distance
The HRM-Pro™ series accessory calculates your running pace and distance based on your user profile and the motion measured by the sensor on every stride. The heart rate monitor provides running pace and distance when GPS is not available, such as during treadmill running. You can view your running pace and distance on your compatible Descent™ watch when connected using ANT+® technology. You can also view it on compatible third-party training apps when connected using Bluetooth® technology.
The pace and distance accuracy improves with calibration.
- Automatic calibration
The default setting for your watch is Auto Calibrate. The HRM-Pro series accessory calibrates each time you run outside with it connected to your compatible Descent watch.NOTE: Automatic calibration does not work for indoor, trail, or ultra run activity profiles (Tips for Recording Running Pace and Distance).
- Manual calibration
You can select Calibrate & Save after a treadmill run with your connected HRM-Pro series accessory (Calibrating the Treadmill Distance).
Parent Topic: Wireless Sensors
