Starting a PacePro Plan
Before you can start a PacePro™ plan, you must download a plan from your Garmin Connect™ account.
- From the watch face, press START.
- Select an outdoor running activity.
- Hold MENU.
- Select Training > PacePro Plans.
- Select a plan.
Press
START.
TIP: You can preview the splits, elevation plot, and the map before you accept the PacePro plan.
- Select Accept Plan to start the plan.
If necessary, select
to enable course navigation.
Press
START to start the activity timer.
Target split pace
Current split pace
Completion progress for the split
Distance remaining in the split
Overall time ahead of or behind your target time
TIP: You can hold MENU, and select Stop PacePro >to stop the PacePro plan. The activity timer continues running.
Parent Topic: PacePro Training
