Changing the Spring Bar Bands
You can replace the bands with new Descent™ G1 bands or compatible QuickFit® 22 bands.
  1. Use the pin tool to push in the watch pin.
    Watch band installation with arrows
  2. Remove the band from the watch.
  3. Select an option:
    • To install Descent G1 bands, align one side of the new band with the holes on the watch, push in the exposed watch pin, and press the band into place.
      NOTE: Make sure the band is secure. The watch pin should align with the holes on the watch.
    • To install QuickFit 22 bands, remove the watch pin from the Descent G1 band, replace the watch pin on the watch, and press the new band into place.
      NOTE: Make sure the band is secure. The latch should close over the watch pin.
  4. Repeat the steps to change the other band.
Copyright © Garmin. All rights reserved.GUID-2A58ED2A-14A3-4161-ADB5-259E1781AF1B v5
