Creating a Custom Workout on Garmin Connect
Before you can create a workout on the Garmin Connect™ app, you must have a Garmin Connect account (Garmin Connect).
Following a Workout From Garmin Connect
Before you can download a workout from Garmin Connect, you must have a Garmin Connect account (Garmin Connect).
Select an option:
Open the Garmin Connect app, and select
Go to connect.garmin.com.
- Select .
- Find a workout, or create and save a new workout.
Select
or Send to Device.
- Follow the on-screen instructions.
Repeating Workout Steps
Before you can repeat a workout step, you must download a workout with at least one step from Garmin Connect (Following a Workout From Garmin Connect).
- Select .
- Select a workout.
- Select .
Select an option:
Select Repeat to repeat a step one or more times. For example, you can repeat a 5-mile step ten times.
Select Repeat Until to repeat a step for a specific duration. For example, you can repeat a 5-mile step for 60 minutes or until your heart rate reaches 160 bpm.
- Select Back To Step, and select a step to repeat.
Select
to save the step.
Editing a Workout
Before you can edit a workout, you must download a workout from Garmin Connect (Following a Workout From Garmin Connect).
- Select .
- Select a workout.
Select
- Select a step.
Change the step attributes, and select
- If necessary, select to delete the step.
Select
to save the workout.
