Garmin Connect
You can connect with your friends on Garmin Connect™. Garmin Connect gives you the tools to track, analyze, share, and encourage each other. Record the events of your active lifestyle including rides, runs, walks, swims, hikes, triathlons, and more.
You can create your free Garmin Connect account when you pair your device with your phone using the Garmin Connect app, or you can go to connect.garmin.com.
Store your activities
After you complete and save an activity with your device, you can upload that activity to Garmin Connect and keep it as long as you want.
Analyze your data
You can view more detailed information about your activity, including time, distance, elevation, heart rate, calories burned, cadence, an overhead map view, pace and speed charts, and customizable reports.
NOTE: Some data requires an optional accessory such as a heart rate monitor.
Mobile app with bike data
Share your activities
You can connect with friends to follow each other's activities or share links to your activities.
Manage your settings
You can customize your bike computer and user settings on your Garmin Connect account.
Using the Garmin Connect App
After you pair your bike computer with your phone, you can use the Garmin Connect app to upload all of your activity data to your Garmin Connect account (Pairing Your Phone).
NOTE: You can customize your bike computer settings, activity profiles, data fields, and user settings on your Garmin Connect account, using either the Garmin Connect app or the Garmin Connect website.
  1. Verify the Garmin Connect app is open or running in the background.
  2. Bring your bike computer within 10 m (30 ft.) of your phone.
    Your bike computer automatically syncs your data with the Garmin Connect app and your Garmin Connect account.
Updating the Software Using the Garmin Connect App
Before you can update your device software using the Garmin Connect app, you must have a Garmin Connect account, and you must pair the device with a compatible phone (Pairing Your Phone).
Sync your device with the Garmin Connect app.
When new software is available, the Garmin Connect app automatically sends the update to your device.
Unified Training Status
When you use more than one Garmin® device with your Garmin Connect account, you can choose which device is the primary data source for everyday use and for training purposes.
From the Garmin Connect app, select Menu symbol > Settings.
Primary Training Device
Sets the priority data source for training metrics like your training status and load focus.
Primary Wearable
Sets the priority data source for daily health metrics like steps and sleep. This should be the watch you wear most often.
TIP: For the most accurate results, Garmin recommends that you sync often with your Garmin Connect account.
Sending Your Ride to Garmin Connect
  • Sync your Edge® bike computer with the Garmin Connect app on your phone.
  • Use the USB cable that came with your Edge bike computer to send ride data to your Garmin Connect account on your computer.
Garmin Coach Training Plans
Your Garmin Connect account has a Garmin coach adaptive training plan to fit your training goals. For example, you can answer a few questions and find a plan to help you achieve a racing milestone or improve your fitness. The plan adjusts to your current level of fitness, schedule preferences, and race date, if applicable. When you start a plan, you can view it on the Garmin coach glance in your glances list on your Edge bike computer (Customizing the Glances).
Using Garmin Connect Training Plans
Before you can download and use a training plan, you must have a Garmin Connect account, and you must pair your Garmin watch or bike computer with a compatible phone (Garmin Connect).‍
  1. From the Garmin Connect app, select Menu symbol.
  2. Select Training & Planning > Garmin Coach Plans.
  3. Select and schedule a training plan.
  4. Follow the on-screen instructions.‍
  5. Review the training plan in your calendar.
Locating a Lost Device
You can use this feature to help locate a lost Garmin device that is within range of a paired phone.
  1. From the Garmin Connect app, select Menu symbol > Garmin Devices.
  2. Select your device.
  3. Select Find My Edge.
    The phone begins searching for the paired Edge Explore 3 bike computer. The bike computer beeps until you press a button.
  4. From the Garmin Connect app, select OK.
Using Garmin Connect on Your Computer
The Garmin Express™ application connects your device to your Garmin Connect account using a computer. You can use the Garmin Express application to upload your activity data to your Garmin Connect account and to send data, such as workouts or training plans, from the Garmin Connect website to your device. You can also install device software updates and manage your Connect IQ™ apps.
  1. Connect the device to your computer using the USB cable.
  2. Go to garmin.com/express.
  3. Download and install the Garmin Express application.
  4. Open the Garmin Express application, and select Add Device.
  5. Follow the on-screen instructions.
Updating the Software Using Garmin Express
Before you can update your device software, you must have a Garmin Connect account, and you must download the Garmin Express application.
    When new software is available, Garmin Express sends it to your device.
  2. Follow the on-screen instructions.
  3. Do not disconnect your device from the computer during the update process.
    NOTE: If you have already set up your Edge Explore 3 Plus device with Wi‑Fi® connectivity, Garmin Connect can automatically download available software updates to your device when it connects using Wi‑Fi.
Garmin Connect+ Subscription
You can enhance the data, connections, and training available on your Garmin Connect account with a Garmin Connect+ subscription. To sign up, you can download the Garmin Connect app from the app store on your phone, or go to connect.garmin.com.
Active Intelligence (AI)
Receive AI insights about your data and activities, including nutrition.
LiveTrack+
Send LiveTrack text messages, receive a personalized profile page, and view previous LiveTrack sessions.
Performance dashboard
View your training data your way with customized charts and graphs, including nutrition metrics.
Social features
Gain access to exclusive badges, badge challenges, and double points for challenges. You can update your profile avatar with customizable frames.
GUID-29C8FC85-6D84-4BD8-8695-745B20B1ED2D v1
October 2026
