Starting the Countdown Timer Select Alarm Clock > > Timer. NOTE: You may need to add this application to the main menu before you can select it (Customizing the Main Menu). Select and to set the time. Select Start Timer. Parent Topic: Setting an AlarmHomeMain Menu ApplicationsSetting an AlarmStarting the Countdown Timer
