Changing the Units of Measure
  1. Select Home.
  2. Select Setup > Units.
  3. Select an option:
    • To change the unit of measure for speed and distance, select Speed/Distance.
    • To change the unit of measure for vertical speed, select Vertical Speed.
    • To change the unit of measure for elevation, select Elevation > Elevation.
    • To change the unit of measure for depth, select Elevation > Depth.
    • To change the unit of measure for temperature, select Temperature.
    • To change the unit of measure for pressure, select Pressure.
  4. Select a unit of measure.
GUID-20A50E5B-3DFB-42C7-A3B4-8D55519B532C v11
February 2026
