Pairing a Wireless Headset with Your Device
Before you can receive navigation prompts through your headset, you must pair your device with a compatible headset with Bluetooth® technology.
NOTE: Only one headset can be active at a time.
  1. Place your headset and your Montana® device within 10 m (33 ft.) of each other.
  2. On your headset, enable Bluetooth technology and make it visible to other Bluetooth devices.
  3. On your Montana device, select Setup > Bluetooth Audio > Audio Device > Add Device.
    A list of nearby Bluetooth devices appears.
  4. Select your headset from the list.
Your device sends navigation prompts to your headset as you navigate a route.
GUID-20A50E5B-3DFB-42C7-A3B4-8D55519B532C v11
February 2026
