Enabling Glide Range Ring on the 'Map' Application Page
  1. With the 'Map' Application Page on the MFW, press the MENU Softkey (on the 'Map' side of the bezel if in split screen mode).
  2. Touch the Map Settings Button.
  3. If necessary, touch the General Tab.
  4. Touch the Glide Range Ring Annunciation Button to enable or disable the Glide Range Ring. The green annunciation indicates the feature is enabled.
  5. To change the Glide range type:
    1. Touch the Glide Range Type Selection Button.
    2. Touch the type of range ring to be displayed on the map (Ring Only/Glide Only/Ring and Glide.
190-03123-21 Rev B
October 2026
