Loading an instrument approach into the flight plan:
- Initiate the Procedure Loading Function for approach (see procedures for Initiating the Procedure Loading Function).
If necessary, select or modify the approach airport:
- Touch the Airport Selection Button.
- Use the keypad, or the Find Function, to enter the approach airport.
- Touch the Enter Button.
- Touch the Approach Procedure Button to display a list of approach procedures.
- Touch the button for the desired instrument approach procedure to select it. Then, the 'Transitions' Window is automatically displayed.
Select or modify the approach transition waypoint:
- If the 'Transitions' Window is not already displayed, touch the Transition Procedure Button to display a list of transition waypoints.
- Touch the button for the desired transition waypoint or touch the VECTORS Button for vectors to final.
- If prompted to fly the course reversal, select the Yes Button or No Button. The system automatically loads the course reversal into the flight plan if the aircraft is outside 180° of the inbound course.
If necessary, select or modify the landing runway:
- Touch the Landing Runway Procedure Button to display a list of runways.
- Touch the button for the desired landing runway.
Enter or modify minimums (only selectable for the Active Flight Plan):
- Touch the Minimums Button.
- Use the keypad to enter the minimums altitude.
If necessary, apply temperature compensation to approach minimums (only available for BARO Mode):
Touch the TEMP COMP Annunciation Buttonto enable the setting. Then, touch the TEMP Datafield Button, and use the keypad and Enter Button to enter the destination temperature.
- Touch the Enter Button to add minimums to the Procedure Loading Function.
If necessary, select a different Approach Mode (Service Level):
- Touch the Approach Menu Button.
- Touch the Service Level Button.
- Touch the Service Button to toggle the selection to 'Manual'.
- Touch each button for the desired Service Level and Vertical Guidance Source settings.
- Touch the Apply Button.
- Touch the Back Arrow to exit the procedure menu.
Touch the
Load and Activate
Button to activate the approach.
Or:
Touch the Load Button.
Parent Topic: Loading an Approach
