Adding A Waypoint To The Active Flight Plan Using The Map Radial Menu:
  1. With the map opened on the MFW touch the desired location to insert into the flight plan.
  2. Touch the dynamic button that identifies the waypoint to be added. This opens the waypoint info for that waypoint.
  3. With a the Waypoint application open, or a 'Waypoint Info' Window open for a specified waypoint, touch the Menu Button.
    Or:
    Press the MENU Softkey (if in split screen mode, press the MENU Softkey on the side of the display the window is open).
  4. Touch the Insert in Flight Plan Button.
  5. Scroll through the "Insert [Waypoint] Before" window and select where the waypoint should be added. Scroll to the bottom of the flight plan to add it to the end of the flight plan.
190-03123-21 Rev B
October 2026
