Adding A Waypoint To The Active Flight Plan From 'Waypoint Info':
  1. With a the Waypoint application open, or a 'Waypoint Info' Window open for a specified waypoint, touch the Menu Button.
    Or:
    Press the MENU Softkey (if in split screen mode, press the MENU Softkey on the side of the display the window is open).
  2. Touch the Insert in Flight Plan Button.
  3. Scroll through the "Insert [Waypoint] Before" window and select where the waypoint should be added. Scroll to the bottom of the flight plan to add it to the end of the flight plan.
190-03123-21 Rev B
October 2026
