Adding and Removing Airways
An airway can only be added if there is a waypoint in the flight plan that is part of the desired airway and is not part of an arrival or approach procedure. The system also anticipates the desired airway based on the selected waypoint and the flight plan.
Some airways have directional restrictions on all or part of the route. Airway “A2” in Europe has a directional restriction over the whole route that can be flown only in the direction MTD-ABB-BNE-DEVAL.
Airway “UR975” in North Africa has more complicated directional restrictions within the list of airway waypoints AMANO, VAKOR, LIBRO, NELDA, DIRKA, GZO, KOSET, and SARKI:
  • Starting from AMANO, the airway can be flown only to LIBRO.
  • Starting from SARKI, the airway can be flown only to LIBRO.
  • Between NELDA and GZO, the airway can be flown in either direction.
In the US, airways that are “one-way” for specified hours of operation are common. These airways are always bidirectional in the system database.
The system only allows correct airway sequences to be inserted. If the pilot subsequently inverts the flight plan, the system inverts the airway waypoint sequence and removes the airway header.
190-03123-21 Rev B
October 2026
