Adding An Individual Airway To A Flight Plan:
  1. On the flight plan page, select a waypoint that is on an airway.
  2. In the 'Waypoint Options' menu touch the Load Airway Button. An 'Airway Selection' window will appear displaying the entry point with the identifier.
  3. Touch the Airway Button to display the 'Select Airway' window.
  4. If necessary scroll through the displayed list and select the desired airway by touching the airway button. A 'Select Exit' window will appear. The default view is listed sequentially, but can be changed to list the waypoints alphabetically by touching the Alphabetical Button.
  5. Select the desired airway exit waypoint by scrolling through the displayed list and touching the exit waypoint. Review the 'Airway Selection' window.
  6. To modify the airway repeat steps three through five. If desired, modify the exit waypoint by touching the Exit Button and repeating step five.
  7. If no modifications are required, touch the Load Button to load the airway into the flight plan.
190-03123-21 Rev B
October 2026
