Loading an Arrival Procedure to the Flight Plan:
  1. Initiate the Procedure Loading Function for departure (see procedures for Initiating the Procedure Loading Function).
  2. If necessary, select or modify the departure airport:
    1. Touch the Airport Selection Button.
    2. Use the keypad, or the Find Function, to enter the departure airport.
    3. Touch the Enter Button.
  3. Touch the Arrival Procedure Button.
  4. Touch the Arrival Button.
  5. If necessary touch the Waypoint Button.
    1. Use the Keypad to enter the desired waypoint.
      Or:
      Use the Find Function and associated tabs to search for a waypoint.
  6. Touch the Arrival Procedure Button and select a procedure from the provided list.
  7. Select an arrival transition:
    1. The transitions window will automatically open after selecting the arrival procedure. Touch the desired Transition Button to add the transition to the arrival procedure.
      Or:
      Touch the Transition Procedure Button to add or edit the transition for the arrival procedure.
  8. The Runways window will automatically open after selecting the arrival transition. If necessary, select or modify the arrival runway:
    1. Touch the desired runway to add it to the arrival procedure.
      Or:
      Touch the Runway Procedure Button to add or edit the runway for the arrival procedure.
  9. Touch the Load Arrival Button
190-03123-21 Rev B
October 2026
