Loading a Departure Procedure to the Flight Plan:
  1. Initiate the Procedure Loading Function for departure (see procedures for Initiating the Procedure Loading Function).
  2. If necessary, select or modify the departure airport:
    1. Touch the Airport Selection Button.
    2. Use the keypad, or the Find Function, to enter the departure airport.
    3. Touch the Enter Button.
  3. If necessary, select or modify the departure runway:
    1. Touch the Runway Button to display a list of runways.
    2. Touch the button for the desired runway.
  4. Touch the Departure Button to display a list of departure procedures.
  5. Touch the button for the desired departure procedure to select it. Then, the 'Transitions' Window is automatically displayed.
  6. Select or modify the departure transition waypoint:
    1. If the 'Transitions' Window is not already displayed, touch the Transition Procedure Button to display a list of transition waypoints.
  7. Touch the Load Departure Button
190-03123-21 Rev B
October 2026
