Adding waypoints to the Active Flight Plan using the Radial Menu:
  1. Touch the desired waypoint on the MFW map display to access the Radial Menu.
  2. Touch the Insert in Flight Plan Button (). (See procedures for Graphical Flight Plan Modifications for using the Graphical Reroute Button instead.)
  3. If multiple waypoints lie within the inner radius, the 'Select From Multiple' Window is displayed. Touch the button for the desired waypoint.
  4. The 'Insert <Waypoint> Before' Window is displayed. Touch a Waypoint Selection Button to select where to insert the new waypoint. The waypoint will be inserted into the flight plan before the selected waypoint.
190-03123-21 Rev B
October 2026
