Viewing Airport Diagrams from the ‘Nearest’ Application Page:
  1. Navigate to the 'Nearest' Application Page
    1. Touch the Nearest Button on the MFW App Bar.
      Or:
    1. Use the Outer DCK (on the MFW side of the bezel while in split screen mode) to scroll to the 'Nearest' Application Page.
      Or:
    1. Touch the Applications Icon > Primary Tab > Nearest.
  2. If necessary select Airport using the Type Button.
  3. Scroll if necessary, touch the desired Airport Button to open the 'Airport Options' Window.
  4. Touch the Waypoint Info Button.
  5. The 'Airport Info' Window will open to the Info Tab, displaying the map location of the selected airport with an inset of the airport diagram. Touch the airport diagram inset to swap between the map and diagram view.
  6. With the airport diagram open the ability to pan and zoom are available.
190-03123-21 Rev B
October 2026
