VNAV Target Altitude Capture Mode (ALTV)
NOTICE
Armed VNAV Target Altitude and Selected Altitude capture modes are mutually exclusive. However, Selected Altitude Capture Mode is armed implicitly (not annunciated) whenever VNAV Target Altitude Capture Mode is armed.
VNAV Target Altitude Capture is analogous to Selected Altitude Capture Mode and is armed automatically after the VNAV Key is pressed on the AFCS Mode Controller or the VNAV Button it touched in the AFCS Control window on the PFW, if the VNAV Target Altitude is to be intercepted before the Selected Altitude. The annunciation ‘ALTV’ indicates the VNAV Target Altitude is to be captured.
As the aircraft nears the VNAV Target Altitude, AFCS automatically transitions to VNAV Target Altitude Capture Mode with Altitude Hold Mode armed. This automatic transition is indicated by the green ‘ALTV’ annunciation flashing for up to 10 seconds and the appearance of the white ‘ALT’ annunciation.
At 50 feet from the VNAV Target Altitude, the AFCS automatically transitions from VNAV Target Altitude Capture to Altitude Hold Mode and selects the VNAV target altitude as the new Autopilot Altitude Reference. As Altitude Hold Mode becomes active, the white ‘ALT’ annunciation moves to the active vertical mode field and flashes green for 10 seconds to indicate the automatic transition.
A VNAV Target Altitude can be specified in several different ways, which result in different system behavior depending on whether the airplane is climbing or descending (as shown in the following table).
Table 59: VNAV Target Altitude Behavior
VNAV Target Altitude Type
VNAV Target Altitude Indication
Climb Behavior
Descent Behavior
At
Arms ALTV
Arms ALTV
At-or-Below
Arms ALTV
Does not arm ALTV1, 2
At-or-Above
Does not arm ALTV1
Arms ALTV
Between
Arms ALTV using the upper altitude
Arms ALTV using the lower altitude
1 Even if ALTV Mode is not armed, the ‘UNABLE VNAV ALTITUDE’ system message will be shown if the airplane’s vertical speed is not sufficient to meet the targeted altitude before crossing the waypoint.
2 Normally, AT-or-BELOW altitudes are not used to define a BOD. However, if an AT-or-BELOW altitude is used in this way, it will be treated as an AT altitude (arming ALTV Mode). Intermediate AT-or-BELOW altitudes in the descent do not arm ALTV.
190-03123-21 Rev B
October 2026
