Instrument Approaches
NOTICE
If certain GPS parameters (SBAS, RAIM, etc.) are not available, some published approach procedures for the desired airport may not be displayed in the list of available approaches.
NOTICE
If flying Direct-to the Final Approach Fix (FAF), and an instrument approach has been loaded, the system will suspend (SUSP) leg sequencing if the approach intercept angle exceeds 45 degrees.
NOTE: AXIS™ Flight Displays will automatically switch the CDI from GPS to VLOC when an ILS approach is loaded once the aircraft is 1 NM from the FAF and has a fix on the approach frequency. This feature works when axis is installed with any non-serial Garmin® navigator.
The system provides guidance for non-precision and precision approaches to airports with published instrument approach procedures. Only one approach per destination can be loaded at a time in a flight plan. The route is defined by selection of an approach, runway, and the transition waypoints.
190-03123-21 Rev B
October 2026
