Viewing TFR Information on the 'Map' or 'Weather' Page:
Navigate to the 'Map' or 'Weather'
Application Page.
Touch the Map Button or Weather
Button on the MFW App Bar.
Or:
Use the Outer DCK (on the MFW side of the bezel in split screen mode) to scroll to the 'Map'
or 'Weather' Application Page.
Or:
- Touch the Applications Icon > Primary Tab > Map or Weather.
Ensure TFRs are enabled on the 'Map' or 'Weather' Page.
- On the 'Map' page, press the MENU Softkey to open the 'Map Menu'.
- Touch the Overlay Selection Button and ensure Weather is the selected overlay option.
- Touch the Map Settings Button.
- Touch the Airspace Tab.
- Touch the TFR/TMOA/TRA Annunciation Button. The green annunciation indicates the feature is enabled.
Touch the Back
Arrow
Or:
Press the BACK Softkey (on the MFW/Weather App side of the bezel in split screen mode) to return to the 'Map' Application Page on the MFW.
Or:
- On the 'Weather' Page, press the MENU Softkey to open the 'Weather Menu'.
- Scroll if necessary and touch the NOTAM - TFRs Annunciation Button. The green annunciation indicates the feature is enabled.
Touch the Back
Arrow
Or:
Press the BACK Softkey (on the MFW/Weather App side of the bezel in split screen mode) to return to the 'Weather' Application Page on the MFW.
- Touch the area of the 'Weather' or 'Map' page that has a TFR icon to open the Radial Menu over the desired TFR to be viewed.
- Touch the TFR Dynamic Button on the Radial Menu to view the TFR information.
Parent Topic: Temporary Flight Restrictions (TFRs)
