Initiating The Procedure Loading Function and Selecting A Procedure:
  1. Navigate to the Applications Quick Actions Tab and touch the PROC Button.
    Or:
    Navigate to the Flight Plan Application on the MFW and touch the airport identifier for which a procedure is to be loaded. Then touch the Load Procedure Button.
  2. Initiate the Procedure Loading Function:
    1. Touch the Departure Button, Arrival Button, or the Approach Button to display the Procedure Loading Function for the selected type of procedure.
  3. Select the procedure:
    1. If necessary, touch the Airport Selection Button and use the keypad or the Find Function to enter or modify the airport identifier.
    2. Touch the Procedure Selection Button to display a list of procedures available at the selected airport for the selected type of procedure.
    3. Touch the button for the desired procedure to select it and return to the Procedure Loading Function.
      The system will automatically run through the series of options for the selected procedure (i.e., Departure, Transition, and Runway). Select each desired option as they appear.
190-03123-21 Rev B
October 2026
