Flight Plan Symbols
The following table lists the flight plan route and waypoint symbols which can be displayed on the map.
Table 17: Flight Plan Symbols
Symbol Name
Description
Symbol
Course Leg
Thick solid line between two waypoints in a flight plan
Heading Leg
Widely spaced arrows directionally indicating the heading of flight plan leg
Roll Steering Path1
Closely spaced arrows indicating a turning path
Missed Approach Leg
Thin gray line used to indicate Missed Approach course.
All Other Legs
Thin dotted line indicating future paths
Turn Anticipation Arc
Curved thick line, used to indicate course leg transition through a fly-by waypoint
Fly-Over Waypoint
Cyan target at waypoint
Along Track Waypoint
Orange square at along track waypoint
Flight Path Fix
Widely spaced arrows leading to a fix, used to indicate a fix that terminates at a manual or specified location
Bottom of Climb/Descent (BOC/BOD)
TOD and BOD, used to indicate vertical transition location
Parallel Offset Waypoint
Waypoint identifier followed by "-p"
1 Roll Steering Path transitions between two disconnected legs (i.e. holding), some procedure turn segments, parallel offset segments, or after some fly-over waypoints.
190-03123-21 Rev B
October 2026
