Fuel Range Ring
Map displays can show a fuel range ring which shows an estimate of the remaining flight distance. A dashed green circle indicates the selected range to fuel reserves. A solid green circle indicates the total endurance range. If only fuel reserves remain, the range is indicated by a solid amber circle. The range ring circle will appear offset from center based on calculations of the current fuel flow, ground speed, and the winds the aircraft are currently experiencing.
153: Fuel Range Ring
190-03123-21 Rev B
October 2026
