Setting the Baro/Temp Comp/Radio Alt Minimum Altitude Alert and Bug:
NOTICE
The Minimum Altitude Alert setting function will default to a barometric setting if a radar altimeter is installed.
  1. Access the 'PFW Menu' window by:
    1. Touch the HSI on the PFW.
    Or:
    1. Press the MENU Softkey on the PFD (if in split screen mode press the MENU Softkey on the PFW side of the bezel).
  2. Touch the Minimums Datafield Button.
  3. Use the Minimums numeric keypad to enter a barometric altitude.
  4. If temperature compensation is required:
    1. Touch the TEMP COMP Annunciation Button.
    2. Touch the TEMP Datafield Button.
    3. Using the Temperature numeric keypad, enter the desired temperature compensation.
    4. Touch the Enter Button on the Temperature numeric keypad.
  5. Touch the Enter Button on the Minimums numeric keypad.
190-03123-21 Rev B
October 2026
