Selecting advanced map settings (General, Aviation, Airspace, Land) for an MFW map display:
  1. Access the 'Map' Application Page:
    1. Touch the Map Button on the MFW App Bar.
      Or:
    1. Touch the Applications Icon on the MFW App Bar.
    2. Touch the Map Button.
      Or:
    1. Use the Outer DCK (on the MFW side of the PFD while in split screen mode) to scroll to the 'Map' Application Page.
  2. With the 'Map' Application Page displayed on the MFW, press the MENU Softkey (on the MFW side of the PFD while in split screen mode) to open the 'Map Menu' Window.
  3. Scroll down and touch the Map Settings Button.
  4. Select the desired tab:
    Touch the General Tab to display settings for synchronization, North Up Above, Autozoom, track vector, and various range rings.
    Or:
    Touch the Aviation Tab to display settings for Runway Extensions and map details (private airports, heliports, low airways, high airways, VORs, Intersections, NDBs, VRPs, and user waypoints).
    Or:
    Touch the Airspace Tab to display settings for TFRs, CL B/TMA/AWY, CL C/CTA, CL A/D, restricted, MOA (Military), or 'Other'.
    Or:
    Touch the Land Tab to display settings for obstacles, wires, roads, railroads, cities, political boundaries, rivers & lakes, LAT/LON lines.
  5. Scroll as required and touch the desired button to display/remove map items.
  6. If a pop up window or drop down list of settings relating to the selected map feature is displayed, touch the button for the desired setting.
190-03123-21 Rev B
October 2026
