Loss of SBAS
NOTICE
Refer to the current, pertinent flight manual for additional information regarding crew responses for loss of SBAS and approach downgrade procedures
Due to the high level of precision required by some approach service levels, losing SBAS may require the pilot to acknowledge a downgrade of approach service level, or to abort the approach. See the following table for approach degradation behavior:
Table 29: Approach Degradation Behavior
Approach
SBAS Becomes Unavailable
Description
Action Required
Downgrade
LNAV
Approach phase not specified
SBAS not required.
The approach is continued.
None
N/A
LNAV+V
LNAV/VNAV
Before the FAF
HSI displays approach service level in amber; VDI displays ‘NO GP’.2
Acknowledge message to redisplay CDI with LNAV 1
LNAV1
At/After the FAF
HSI displays downgraded approach service level in magenta;
None
LNAV1
LP
More than one minute to the FAF
None
N/A
Within one minute to the FAF
CDI is removed.2
LNAV 1
At/After the FAF
CDI is removed.2
Acknowledge ABORT APR message to redisplay CDI
N/A
LP+V
None
N/A
HSI displays downgraded approach service level in amber;
CDI is removed.
VDI displays ‘NO GP’. 2
Acknowledge message to redisplay CDI with LNAV+V 1 Glidepath
LNAV+V 1
At/After the FAF
CDI is removed.
N/A
LPV
None
N/A
None
LNAV/VNAV1
At/After the FAF
None
LNAV1
1 Some approaches may not publish minimums for the downgrade given as an example in this table. The system will select the appropriate downgrade, if available, for each published approach as it is derived from the database. If an appropriate downgrade is not available, the approach should be aborted.
2 System message is generated.
190-03123-21 Rev B
October 2026
