Customizing the Varia Device Settings with Your Edge 1040
Before you can customize Varia™ eRTL616 settings with your Edge® 1040, you must pair the devices.
  1. Select Menu symbol > Sensors > Lights.
  2. Select an option:
    • Select Enable to enable the light network.
    • Select Network Options > Test Lights to verify that each light in your network is set up correctly (Testing the Light Network).
    • Select a light to view device information and customize each light in your network (Light Network Settings).
GUID-1F013ED0-E74B-4883-9CBB-E41B6B7BB185 v2
March 2024
