Activities and App Settings
These settings allow you to customize each preloaded activity app based on your needs.‍ For example, you can customize data pages and enable alerts and training features.‍ Not all settings are available for all activity types.
Hold MENU, select Activities & Apps, select an activity, and select the activity settings.
3D Distance
Calculates your distance traveled using your elevation change as well as your horizontal movement over ground.
3D Speed
Calculates your speed using your elevation change as well as your horizontal movement over ground.
Accent Color
Sets the accent color for the activity icon.
Add Activity
Adds an activity type to a multisport activity.
Alerts
Sets the training or navigation alerts for the activity (Activity Alerts).
Altimeter
Displays the pressure altitude, or GPS altitude, when the watch has a GPS fix.
Auto Climb
Detects elevation changes using the built-in altimeter and automatically displays relevant climb data (Enabling Auto Climb).
Auto Fly
In watch mode, starts a flight activity automatically when the detected climb rate exceeds a specified speed. The activity stops when the ground speed drops below 30 kt for a specified time.
Auto Lap
Sets the options for the Auto Lap® feature to automatically mark laps. The Auto Distance option marks laps at a specific distance. The Auto Position option marks laps at a location where you previously pressed LAP. When you complete a lap, a customizable lap alert message appears. This feature is helpful for comparing your performance over different parts of an activity.
Auto Pause
Sets the options for the Auto Pause® feature to stop recording data when you stop moving or when you drop below a specified speed. This feature is helpful if your activity includes stop lights or other places where you must stop.
Auto Rest
Automatically creates a rest interval when you stop moving during a pool swim activity (Swim Auto Rest and Manual Rest). Sets the options for automatically starting and stopping the rest timer for the ultra run activity (Ultra Run Auto Rest Settings).
Auto Run
Automatically detects ski or water sport runs using the built-in accelerometer (Viewing Your Ski Runs, Viewing Your Water Sport Runs).
Auto Scroll
Automatically scrolls through all of the activity data screens while the activity timer is running.
Auto Set
Automatically starts and stops exercise sets during a strength training activity.
Auto Sport Change
Automatically detects a transition to the next sport in a multisport activity, such as a triathlon.
Auto Start
Automatically starts a motocross or BMX activity when you start moving.
Big Numbers
Changes the size of the numbers on the data screens (Big Numbers Mode).
Broadcast Heart Rate
Automatically broadcasts heart rate data from your watch to paired devices when you start the activity (Broadcasting Heart Rate Data).
Broadcast to GameOn
Automatically broadcasts biometrics data to the Garmin GameOn™ app when you start a gaming activity (Using the Garmin GameOn App).
ClimbPro
Displays ascent information for upcoming and current climbs while navigating a course (Using ClimbPro).
Club Prompt
Prompts you to enter which golf club you used after each detected shot to record your club statistics (Recording Statistics).
Countdown Start
Enables a countdown timer for pool swimming intervals.
Data Screens
Customizes data screens and adds new data screens for the activity (Customizing the Data Screens).
Driver Distance
Sets the average distance the ball travels on your drive while playing golf.
Edit Weight
Prompts you to add the weight used for an exercise set during a strength training or cardio activity.
Flight Timer
From the Fly activity, automatically starts and stops the flight timer when your ground speed exceeds the value set in the Flight Timer Threshold option.
From the Fly activity, automatically starts and stops the flight timer when your ground speed exceeds this value. For example, 30 kt.
Golf Distance
Sets the unit of measure for distance while playing golf.
Golf Wind Speed
Sets the unit of measure for wind speed while playing golf.
Grading System
Sets the grading system for rating the route difficulty for a rock climbing activity.
Jump Mode
Sets the jump rope activity target to a set time, number of reps, or open ended.
Lane Number
Sets your lane number for track running.
Lap Key
Enables the LAP button for recording a lap or rest during an activity.
Lock Device
Locks the touchscreen and buttons during a multisport activity to prevent inadvertent button presses and touchscreen swipes.
Map
Sets the display preferences for the map data screen for the activity (Activity Map Settings).
Map Layers
Sets the map data to show on the map (Showing and Hiding Map Data).
Metronome
Plays tones or vibrates at a steady rhythm to help you improve your performance by training at a faster, slower, or more consistent cadence. You can set the beats per minute (bpm) of the cadence you want to maintain, beat frequency, and sound settings.
Mode Tracking
Sets the ascent and descent tracking mode to automatic or manual for backcountry skiing and snowboarding.
Obstacle Tracking
Saves obstacle locations from your first loop of the course. On repeat loops of the course, the watch uses the saved locations to switch between obstacle and running intervals (Recording an Obstacle Racing Activity).
PlaysLike
Configures the "plays like" distance feature, which shows adjusted distances to the green while playing golf ( PlaysLike Distance Icons).
Pool Size
Sets the pool length for pool swimming.
Power Averaging
Controls whether the watch includes zero values for bike power data that occur when you are not pedaling.
Power Mode
Sets the default power mode for the activity.
Power Save Timeout
Sets the timeout limit for the watch to stay in activity mode while waiting for you to start the activity, for example, when you are waiting for a race to start. The Normal option sets the watch to enter low-power watch mode after 5 minutes of inactivity. The Extended option sets the watch to enter low-power watch mode after 25 minutes of inactivity. The extended mode can result in shorter battery life between charges.
Record Activity
Enables activity FIT file recording for golf activities. FIT files record fitness information that is tailored for the Garmin Connect™ website and app.
Record After Sunset
Sets the watch to record track points after sunset during an expedition.
Record Temperature
Records the ambient temperature around the watch or from a paired temperature sensor.
Record VO2 Max.
Records a VO2 max. estimate for trail run and ultra run activities.
Recording Interval
Sets the frequency for recording track points during an expedition. By default, GPS track points are recorded once an hour, and they are not recorded after sunset. Recording track points less frequently maximizes battery life.
Rename
Sets the activity name.
Rep Counting
Records rep counts during a workout. The Workouts Only option records rep counts during guided workouts only.
Repeat
Records repeats for multisport activities. For example, you can use this option for activities that include multiple transitions, such as a swimrun.
Restore Defaults
Resets the activity settings.
Route Stats
Records route statistics for indoor climbing activities.
Routing
Sets the preferences for calculating routes for the activity (Routing Settings).
Running Power
Records running power data and customizes the settings (Running Power Settings).
Satellites
Sets the satellite system to use for the activity (Satellite Settings).
Scoring
Sets your golf scoring preferences, enables statistics tracking, and sets your handicap (Scoring Settings).
Segments
Displays your saved segments for the activity (Segments). The Auto Effort option automatically adjusts the target race time of a segment based on your performance during the segment.
Segment Alerts
Notifies you about approaching saved segments (Segments).
Self Evaluation
Sets how often you evaluate your perceived effort for the activity (Evaluating an Activity).
SpeedPro
Records advanced speed metrics for windsurf activity runs.
Stroke Detect.
Automatically detects your stroke type for pool swimming.
Swimrun Auto Sport Change
Automatically transitions between the swim portion and the run portion of a swimrun multisport activity.
Touch
Enables the touchscreen during an activity.
Tournament Mode
Disables features that are not allowed during sanctioned golf tournaments.
Transitions
Enables transitions for multisport activities.
Units
Sets the units of measure for the activity.
Vibration Alerts
Notifies you to inhale or exhale during a breathwork activity.
Virtual Caddie
Shows virtual caddie club recommendations automatically, or you can manually access them from the menu. Appears after you play five rounds of golf, track your clubs, and upload your scorecards to the Garmin Golf™ app.
Workout Videos
Plays instructive workout animations for a strength, cardio, yoga, or Pilates activity. Animations are available for pre-installed workouts and workouts downloaded from your Garmin Connect account.
GUID-1E5740B3-60A1-4890-B39A-7587060D785A v9
August 2025
