Mounting Considerations
NOTICE
This device should be mounted in a location that is not exposed to extreme temperatures or conditions. The temperature range for this device is listed in the product specifications. Extended exposure to temperatures exceeding the specified temperature range, in storage or operating conditions, may cause device failure. Extreme-temperature-induced damage and related consequences are not covered by the warranty.
When selecting a mounting location, you should observe these considerations.
  • The location should provide optimal viewing as you operate your boat.
  • The location should allow for easy access to all device interfaces, such as the keypad, touchscreen, and card reader, if applicable.
  • The location must be strong enough to support the weight of the device and protect it from excessive vibration or shock.
  • To avoid interference with a magnetic compass, the device should not be installed closer to a compass than the compass-safe distance value listed in the product specifications.
  • The location must allow room for the routing and connection of all cables.
  • The location must not be a flat, horizontal surface. The location should be in a vertical angle.
    The location and viewing angle should be tested before you install the device. High viewing angles from above and below the display may result in a poor image.
GUID-1D10BCD0-0E11-47B4-A319-12BED4E1FF9E v4
January 2025
