Bail Mounting the Device
NOTICE
If you are mounting the bracket on fiberglass with screws, it is recommended to use a countersink bit to drill a clearance counterbore through only the top gel-coat layer. This will help to avoid cracking in the gel-coat layer when the screws are tightened.
The bail-mounting hardware (screws and washers, or nuts, washers, and bolts) is not included. The bail mount bracket is included in some models. Before you can bail mount the device, you must purchase a bail mount bracket, if necessary. You must also purchase mounting hardware that fits the holes in the bail mount bracket and securely attaches it to your specific mounting surface. The size of the pilot holes required depends on the mounting hardware you purchase.
  1. Using the bail mount bracket Callout number 1 as a template, mark the location of the four pilot holes Callout number 2.
    Device bail-mount installation with callouts
  2. Using a drill bit appropriate for your mounting hardware, drill the pilot holes.
  3. Secure the bail mount bracket to the surface using your mounting hardware Callout number 3.
  4. Install the bail mount knobs Callout number 4 on the sides of the device.
  5. Place the device in the bail mount bracket, and tighten the bail mount knobs.
GUID-1D10BCD0-0E11-47B4-A319-12BED4E1FF9E v4
January 2025
