Specifications
All Models
Material
Polycarbonate plastic
Water rating
IEC 60529 IPX71
Temperature range
From -15° to 55°C (from 5° to 131°F)
Clearance to nearest obstruction behind chartplotter
150 mm (57/8 in.)
Input voltage
From 9 to 18 Vdc
12Vdc 일반
Fuse
8 A, fast-blow (included)
Display resolution (W x H)
1280 x 800 pixels
Display type
WXGA
Memory card
2 microSD® card slots; 1 TB max. card size2
Wireless frequency
2.4 GHz @ 16.6 dBm maximum
무선 전력
Wi‑Fi®: 10dBm/MHz 미만
Bluetooth®: 3mW 미만
ANT®: 10mW 미만
Sonar frequencies3
Traditional L, M, H CHIRP: 50/77/83/200 kHz
Garmin ClearVü™ CHIRP: 260/455/800/1000/1200 kHz
Garmin SideVü™ CHIRP: 260/455/800/1000/1200 kHz
Sonar transmit power (RMS)4
CHIRP: 600 W
Garmin ClearVü and Garmin SideVü CHIRP: 600 W
Sonar depth5
701 m (2,300 ft.) at 77 kHz
100 Series Models
Dimensions, device only (W x H x D)
295 x 195 x 98 mm (115/8 x 711/16 x 37/8 in.)
Dimensions, in bail mount with sun cover (W x H x D)
314 x 211 x 114 mm (123/8 x 85/16 x 41/2 in.)
Display size (W x H)
218 x 137 mm (89/16 x 53/8 in.)
257 mm (10 in.) diagonal
Weight
1.75 kg (3 lb. 14 oz.)
Max. power draw
34 W
Typical current draw at 12 Vdc (RMS)
2.3 A
Max. current draw at 12 Vdc (peak)
5 A
Compass-safe distance
10 cm (3.9 in.)
120 Series Models
341 x 229 x 98 mm (137/16 x 9 x 37/8 in.)
352 x 235 x 114 mm (137/8 x 91/4 x 41/2 in.)
262 x 164 mm (105/16 x 615/32 in.)
309 mm (12 in.) diagonal
Weight
2.46 kg (5 lb. 7 oz.)
Max. power draw
36 W
2.5 A
5 A
9 cm (3.5 in.)
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
2 As of software version 35.00, this device is compatible with up to 1 TB memory cards formatted to exFAT.
3 Dependent upon the transducer.
4 Dependent upon the transducer rating and depth.
5 Dependent upon the transducer, water salinity, bottom type, and other water conditions.
GUID-1580D9B7-F2D2-4EBF-A08A-B7A34B2EDD65 v2
January 2025
