Position Format Settings
NOTE:
Do not change the position format or the map datum coordinate system unless you are using a map or chart that specifies a different position format.
Select .
- Coordinate Format
Sets the position format for the location information.
- Display Format
Sets the format in which coordinates will appear on the device.
- Datum
Sets the coordinate system on which the map is structured.
- Map Spheroid
Shows the coordinate system the device is using. The default coordinate system is WGS 84.
Parent Topic: Map Settings
