Map settings
Select Settings > Map Display.
Map Vehicle Icon
Sets the vehicle icon that represents your position on the map.
Driving Map View
Sets the perspective used while viewing the map.
Map Detail
Sets the level of detail on the map. More detail may cause the map to be drawn more slowly.
Waypoint Labels
Sets the size of waypoint labels on the map.
Waypoint Decluttering
Hides waypoint icons at high map zoom levels.
Range Rings
Shows rings on the map, representing distance from you. The distance to the innermost ring appears in the bottom left-hand corner of the screen.
NOTE: Range rings are shown only while using the Track Up or North Up map perspective (Changing the map perspective).
Auto Zoom
Automatically selects the zoom level for optimal use of your map. When disabled, you must zoom in or out manually.
Skip Next Stop Confirmation
Sets a confirmation message to appear when skipping a location on your route.
Units
Sets the units of measure.
Position Format
Sets the format used for geographical position coordinates and the coordinate system used by the map (Position Format Settings).
Map Manager
Manages maps installed on the device.
GUID-157A2412-594F-45D8-A5EE-5A5327DA0914 v9
December 2025
