Position Format Settings
NOTE: Do not change the position format or the map datum coordinate system unless you are using a map or chart that specifies a different position format.
Select Settings > Map Display > Position Format.
Coordinate Format
Sets the position format for the location information.
Display Format
Sets the format in which coordinates will appear on the device.
Datum
Sets the coordinate system on which the map is structured.
Map Spheroid
Shows the coordinate system the device is using. The default coordinate system is WGS 84.
GUID-157A2412-594F-45D8-A5EE-5A5327DA0914 v9
December 2025
