Installing the Jack Plate Mount in Downward or Forward Mode
  1. Confirm that the tilt bracket is installed with the bolts located in the slots marked with D.
    NOTE: If the bolts aren't in the D slot, you must remove them, rotate the tilt bracket, and reinstall them in the correct slot.
  2. Rotate the transducer 1 to adjust the angle of the sonar beam.
    Adjusting the jack plate mount for downward or forward mode with callouts
    As a starting point, align the marking on the transducer with the 30-degrees slot closest to the jack plate. From there you can test the results on your vessel and adjust the angle as needed. Every boat is different and you may need a different angle for the best performance.
  3. Adjust the height of the jack plate bracket 2 to ensure the transducer is submerged when the boat is in the water.
    NOTE: If you must move the transducer deeper than the slots on the jack plate bracket, you can rotate the transducer bracket 3.
GUID-1492D076-511B-4A9A-9FF1-C8C50EA630BA v1
October 2026
