Installing the Jack Plate Mount in Perspective Mode
  1. Confirm that the tilt bracket is installed with the bolts located in the slots marked with P.
    NOTE: If the bolts aren't in the P slot, you must remove them, rotate the tilt bracket, and reinstall them in the correct slot.
  2. Rotate the tilt bracket 1 so that the transducer is angled slightly downward.
    Adjusting the jack plate mount for perspective mode with callouts
    NOTE: An angle of approximately 7.5 degrees is recommended for best sonar performance, but you may need to adjust this angle depending on your experience. Each tick mark on the tilt bracket represents 7.5 degrees.
  3. Adjust the height of the jack plate bracket 2 to ensure the transducer is submerged when the boat is in the water.
GUID-1492D076-511B-4A9A-9FF1-C8C50EA630BA v1
October 2026
