Installing the NEO Motion Plates You can use the NEO Motion Plates accessory with any Tacx ® NEO trainer. Remove the 4 feet from the Tacx NEO trainer. Store the feet on the NEO Motion Plates. Lift the left side of the Tacx NEO trainer, and align the left plate. Lift the right side of the Tacx NEO trainer, and align the right plate. Check the alignment of the plates on both sides. You may need to lift and adjust each side to align the plates correctly. NOTE: Both plates must be fully seated. Parent Topic: Important Safety and Product InformationHomeImportant Safety and Product InformationInstalling the NEO Motion Plates
