Connecting the Transducer to a Chartplotter
Select Force® Kraken Trolling Motor models include a built-in transducer. If your model does not include a transducer, you must install one before you can connect it to a compatible chartplotter.The built-in 12-pin transducer is compatible with select Garmin® chartplotter models. Go to garmin.com or contact your Garmin dealer for more information.
  1. Route the transducer cable to the installed chartplotter. If necessary, connect the included extension cable or a longer extension cable.
  2. Install the locking collar on the end of the transducer cable.
  3. Connect the transducer cable to the transducer port on the back of the chartplotter.
    You can refer to the instructions provided with your chartplotter to identify the transducer port.
GUID-09FCEEF1-A8CD-4B9C-8A62-161A75852017 v10
January 2026
