Getting Started
WARNING
See the Important Safety and Product Information guide in the product box for product warnings and other important information.
WARNING
Failure to install this device according to these instructions could result in personal injury, damage to the vessel or device, or poor product performance.
WARNING
Do not run the motor when the propeller is out of the water. Contact with the rotating propeller may result in severe injury.
WARNING
Do not use the motor in areas where you or other people in the water may come into contact with the rotating propeller, which could result in severe injury.
WARNING
Always disconnect the motor from the battery before handling or working with the propeller, propeller drive motor, electrical connections, or electronics enclosures to avoid serious injury or death.
CAUTION
For the best possible performance and to avoid potential injury, damage to the device, or damage to your vessel, installation by a qualified marine installer is recommended.
CAUTION
To avoid possible personal injury, always wear safety goggles, ear protection, and a dust mask when drilling, cutting, or sanding.
CAUTION
When stowing or deploying the motor, be aware of the risk of entrapment or pinching from moving parts, which can result in personal injury.
CAUTION
When stowing or deploying the motor, maintain stable footing and be aware of slick surfaces around the motor. Losing your footing while stowing or deploying the motor may result in injury.
NOTICE
When drilling or cutting, always check what is on the opposite side of the surface to avoid damaging the vessel.
GUID-09FCEEF1-A8CD-4B9C-8A62-161A75852017 v10
January 2026
