Important Safety Information
See the Important Safety and Product Information guide in the product box for product warnings and other important information.
This device must be installed according to these instructions. Failure to install this device in accordance with these instructions could result in serious personal injury, damage to the device, or poor product performance.
To avoid possible serious personal injury or damage to the device, disconnect the speaker's power cord during installation of the device.
Handle with care, especially when positioning the device before normal use or when relocating for service. Failure to use caution when positioning the device could cause the device to tip, resulting in crushed body parts or other severe injury.
To avoid potential injury or property damage, a two-person lift is required.
During normal use, the speaker should be placed on a level surface to avoid tipping, which could cause potential product damage or severe personal injury.
To prevent possible product damage, do not position the device near other sources of heat, such as radiators, heat registers, stoves, or fireplaces.
During normal operation, the device should be placed on a level surface to avoid instability.
When selecting a suitable location for the speaker, make sure the full weight of the stand and speaker can be supported.
Route all speaker cables and the power supply cable to avoid being walked on or pinched by items placed on or against them.
For best possible performance and to avoid potential injury, damage to the device, or other property damage, installation by a professional installer is recommended.
You must read all installation instructions before beginning the installation. If you experience difficulty during the installation, go to support.garmin.com for product support.
