Preparing the Speaker
CAUTION
To avoid potential injury or property damage, a two-person lift is required.
  1. Remove the speaker's top panel and both side panels.
  2. Flip the bottom foam insert over and place it on the ground near the speaker's final location.
  3. Carefully place the speaker with its back facing down on the bottom foam insert.
  4. Using the included hex key, remove the speaker's base 1.
    Exploded view of the Primacy S3 speaker and base with callouts
  5. Using the included hex key, remove the speaker's post 2.
  6. Using the included hex key, remove the top plate 3 from the speaker's post.
You must save and reuse the screws from the speaker's post and top plate.
GUID-01BDC3A7-6C48-4F80-BE5C-BD0E0D7E0CE7 v2
May 2026
